java.lang.ClassCastException: Error trying to coerce 'NA' to a number.
at com.inductiveautomation.ignition.common.TypeUtilities.toNumber(TypeUtilities.java:800)
at com.inductiveautomation.ignition.common.TypeUtilities.coerce(TypeUtilities.java:1146)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.setQValue(AbstractPropertyAdapter.java:223)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateValue(AbstractPropertyAdapter.java:269)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:89)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.startup(ExpressionPropertyAdapter.java:113)
at com.inductiveautomation.factorypmi.application.binding.DefaultInteractionController.startupBindings(DefaultInteractionController.java:355)
at com.inductiveautomation.factorypmi.application.binding.DefaultInteractionController.startupAdapters(DefaultInteractionController.java:360)
at com.inductiveautomation.factorypmi.application.FPMIWindow.startup(FPMIWindow.java:344)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$DesigntimeWindowOpener.openWindow(WindowWorkspace.java:3737)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openWindow(WindowWorkspace.java:1478)
at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl$DesignableProjectListener.updateResources(VisionDesignerImpl.java:1760)
at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl$DesignableProjectListener.resourcesModified(VisionDesignerImpl.java:1703)
at com.inductiveautomation.ignition.common.project.AbstractProject.notifyResourceListeners(AbstractProject.java:351)
at com.inductiveautomation.ignition.common.project.AbstractProject.updateEffectiveState(AbstractProject.java:153)
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.modifyResource(DesignerProjectTreeImpl.java:170)
at com.inductiveautomation.ignition.designer.project.DesignableProject.createOrModify(DesignableProject.java:160)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.saveContainer(WindowWorkspace.java:1794)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.commitDesignable(WindowWorkspace.java:1496)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.commitAll(WindowWorkspace.java:1065)
at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.notifyProjectSaveStart(VisionDesignerImpl.java:552)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.commitAll(IgnitionDesigner.java:1593)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.handleSave(IgnitionDesigner.java:1358)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.export(IgnitionDesigner.java:1247)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.export(IgnitionDesigner.java:1241)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.export(IgnitionDesigner.java:1224)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler$10.actionPerformed(IgnitionDesigner.java:2400)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
at com.inductiveautomation.snap.swing.RibsEventQueue.dispatchEvent(RibsEventQueue.java:99)
Ignition v8.1.9 (b2021080617)
Java: Azul Systems, Inc. 11.0.11
I am getting 4 similar errors when i open a window in Designer
