OK… this one is just killing me… and the answer is probably ‘DOH’ simple:
Trying to multiply two UDT tag values to get a result.
UDT
----- Tag1 (expression tag) (float8) – has a working expression
----- Tag2 (expression tag) (float8) – will be a user input value
----- Tag3 (expression tag) (float8) – the result
Tag3 expression:
toFloat({[~]UDT/Tag1}) * toFloat({[~]UDT/Tag2})
I’ve tried other versions using tag(toFloat( and tag(
I think those references are simply incorrect. If all three tags are side by side like you describe, try:
{[.]Tag1}*{[.]Tag2}
When you use [~], it’s going to the root of the tag provider, which I doubt is what you want. It didn’t give you that through a tag selector, did it? If so, what version are you using?
Otherwise, perhaps you could export the udt in question, and I could try to import it.
Perhaps I am trying to do something outside of the scope of Ignition. Note that the above does work if I throw it into an expression for a numeric field value.
Meanwhile... I'm reading through documentation. Thanks!
