TypeError: 'stringmap' object is not callable when using system.util.globals
I want to setup a in memory cache for my report data .
62 obj={'Mon May 23 00:00:00 CAT 2022':[68.0, 49.0, 24.0, 33.0, 39.0, 46.0],
63 'Mon May 30 00:00:00 CAT 2022': [54.0, 64.0, 18.0, 25.0, 51.0, 27.0],
64 'Mon Jun 06 00:00:00 CAT 2022': [54.0, 64.0, 18.0, 26.0, 50.0, 28.0],
65 'Mon Jun 13 00:00:00 CAT 2022': [59.0, 47.0, 20.0, 28.0, 38.0, 40.0]}
66 system.util.globals()['reportCache']={'weeklyTotals':obj}
I am trying to use system.util.globals() function but when I run it ,I get the following error.
  File "<input>", line 66, in <module>
It's either system.util.getGlobals() or system.util.globals. You can't call globals.
Thank you , that was the mistake
Huh, the example in the doc page makes the same mistake:
@Paul.Scott I believe this might be of interest to you
Just ran into the same issue. Documentation does need an edit
