I’ve been evaluating Ignition on my laptop and every time I change wireless networks the connection to the UA Server is broken and never comes back. The only way that I have found to fix it so far is to uninstall and reinstall Ignition, is there something I am doing wrong?
You’re probably going to have issues because your IP address is changing when you change networks. Under “OPC-UA > Settings” on the Ignition gateway there is a setting called Endpoint Address. Next time you change networks go set this to the IP address you receive and then restart the UA module.
That fixed it. I was changing the endpoint address, but I had never restarted the UA module.
Thanks for your help.
