maknem
August 18, 2026, 7:41pm
1
I have trial version of Ignition 8.3.8. I am trying to use the OPC Server in UaExpert OPC client on same host. OPC server is set with below settings
In trusted certificates I see only Ignition OPC UA Server. Quarantined Certificates is blank.
At UaExpert server I have below
I am using default password.
I see below in logs
Use the "Custom Discovery" workflow instead:
Alternatively, you need to enable the "None" security option in Ignition because UaExpert has a bug where it assumes it's going to be able to do unsecured discovery.
maknem
August 18, 2026, 8:10pm
3
I tried to add server using custom discovery
It gets added, but in the log I see
When I see the connection properties I see below
Have you accepted/trusted the UaExpert certificate in Ignition?
Did you recently add the "Sign" option but not yet restart the Ignition Gateway?
What's in the Ignition logs?
maknem
August 18, 2026, 8:20pm
5
I changed security policies to None and Security Mode to Sign
Restarted ignition service.
Tried to add server by custom discovery again, the server got added with below settings
I can browse tags now.
not sure why it does not allow w/ security policy as Basic256ha256 & security mode as SignAndEncrypt
