I’m receiving this error when logging to UA server:
UaServiceFaultException: status=Bad, message=Bad; unspecified.
at org.eclipse.milo.opcua.stack.client.UaTcpStackClient.receiveResponse(UaTcpStackClient.java:294)
at org.eclipse.milo.opcua.stack.client.UaTcpStackClient.lambda$sendRequest$3(UaTcpStackClient.java:147)
at java.util.concurrent.CompletableFuture.uniWhenComplete(CompletableFuture.java:760)
at java.util.concurrent.CompletableFuture$UniWhenComplete.tryFire(CompletableFuture.java:736)
at java.util.concurrent.CompletableFuture.postComplete(CompletableFuture.java:474)
at java.util.concurrent.CompletableFuture.complete(CompletableFuture.java:1962)
at org.eclipse.milo.opcua.stack.client.handlers.UaTcpClientMessageHandler.lambda$null$19(UaTcpClientMessageHandler.java:539)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
What does it mean?
Nothing, without more information/logs, unfortunately.
Sorry, I forgot to say that I’m a newbie with Ignition and actually I’m using my free time to learn this SW platform because we several quotations that included it. I’m with a clean installation. I’ve just change the endpoint of the UA server.
Attached the first page of the log file
XOPCGatewayHook	02Mar2017 16:25:24	Licensing state changed. LicenseState[TRIAL, expired=true] -> LicenseState[TRIAL, expired=false]
LicenseManager	02Mar2017 16:25:24	Trial time reset. Time remaining = 7200.
XOPCGatewayHook	02Mar2017 15:55:22	Licensing state changed. LicenseState[TRIAL, expired=false] -> LicenseState[TRIAL, expired=true]
QuickClientSubscriptionManager	02Mar2017 14:41:44	Unsubscribing abandoned quick client subscription: Subscription 1_76C5D312
InternalDatabase	02Mar2017 14:37:24	Created auto-backup of internal database “config.idb” in 709 ms
InternalDatabase	02Mar2017 14:37:23	Creating auto-backup of internal database “config.idb”…
InternalDatabase	02Mar2017 14:35:23	Created auto-backup of internal database “config.idb” in 7 seconds
InternalDatabase	02Mar2017 14:35:16	Creating auto-backup of internal database “config.idb”…
PropertiesFactory	02Mar2017 14:14:20	Loading properties files from jar:file:/C:/Program%20Files/Inductive%20Automation/Ignition/webserver/webapps/main/WEB-INF/lib/wicket-extensions-6.1.1.jar!/org/apache/wicket/extensions/wizard/Wizard.properties with loader org.apache.wicket.resource.IsoPropertiesFilePropertiesLoader@4e641705
InternalDatabase	02Mar2017 14:05:16	Created auto-backup of internal database “config.idb” in 536 ms
InternalDatabase	02Mar2017 14:05:15	Creating auto-backup of internal database “config.idb”…
UaTcpClientAcknowledgeHandler	02Mar2017 14:05:09	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:05:04	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:04:59	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:04:54	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:04:49	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:04:44	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:04:39	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:04:34	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:04:29	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:04:24	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:04:19	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:04:14	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:04:09	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:04:04	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:03:59	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:03:54	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:03:49	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:03:44	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:03:39	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:03:34	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:03:29	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:03:24	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:03:19	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:03:14	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:03:09	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:03:04	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:02:59	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:02:54	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:02:49	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:02:44	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:02:39	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:02:34	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:02:29	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:02:24	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:02:19	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:02:14	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:02:09	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:02:04	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:01:59	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:01:54	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:01:49	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:01:44	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
PropertiesFactory	02Mar2017 14:01:40	Loading properties files from jar:file:/C:/Program%20Files/Inductive%20Automation/Ignition/webserver/webapps/main/WEB-INF/lib/wicket-extensions-6.1.1.jar!/org/apache/wicket/extensions/Initializer.properties with loader org.apache.wicket.resource.IsoPropertiesFilePropertiesLoader@4e641705
PropertiesFactory	02Mar2017 14:01:40	Loading properties files from jar:file:/C:/Program%20Files/Inductive%20Automation/Ignition/webserver/webapps/main/WEB-INF/lib/wicket-core-6.1.1.jar!/org/apache/wicket/Application.properties with loader org.apache.wicket.resource.IsoPropertiesFilePropertiesLoader@4e641705
UaTcpClientAcknowledgeHandler	02Mar2017 14:01:39	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:01:34	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:01:29	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:01:24	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:01:19	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:01:14	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:01:09	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:01:04	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:00:59	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:00:54	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:00:49	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:00:44	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:00:39	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:00:34	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:00:29	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
UaTcpClientAcknowledgeHandler	02Mar2017 14:00:24	[remote=/192.168.2.76:49320] Received error message: ErrorMessage{error=StatusCode{name=Bad_CertificateInvalid, value=0x80120000, quality=bad}, reason=null}
It looks like you’re trying to make a connection to Kepware but haven’t gone into the Kepware UA configuration and marked Ignition’s client certificate as trusted yet.
Really I did it, and the same problem occurs even when I try to connect Ignition OPC-UA Server
You should probably call into support and let them help you out over a GoToMeeting session.
Only the last msg then I’ll try your way. I cleaned the logfile and restart the gateway and now I have this:
XOPCModule	02Mar2017 17:08:39	Error starting XOPCServer.
java.net.BindException: Address already in use: JVM_Bind
at java.net.DualStackPlainSocketImpl.bind0(Native Method)
at java.net.DualStackPlainSocketImpl.socketBind(DualStackPlainSocketImpl.java:106)
at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:387)
at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:190)
at java.net.ServerSocket.bind(ServerSocket.java:375)
at java.net.ServerSocket.(ServerSocket.java:237)
at java.net.ServerSocket.(ServerSocket.java:128)
at javax.net.DefaultServerSocketFactory.createServerSocket(ServerSocketFactory.java:218)
at com.inductiveautomation.xopc.server.core.XOPCServer$TCPAcceptor.(XOPCServer.java:399)
at com.inductiveautomation.xopc.server.core.XOPCServer.startup(XOPCServer.java:195)
at com.inductiveautomation.xopc.server.core.XOPCModule.init(XOPCModule.java:181)
at com.inductiveautomation.xopc.server.core.XOPCModule.createInstance(XOPCModule.java:203)
at com.inductiveautomation.xopc.server.core.XOPCGatewayHook.startup(XOPCGatewayHook.java:275)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.startup(ModuleManagerImpl.java:2110)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.startup(ModuleManagerImpl.java:362)
at com.inductiveautomation.ignition.gateway.SRContext.startupInternal(SRContext.java:1375)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:233)
at com.inductiveautomation.ignition.gateway.SRContext.asyncInit(SRContext.java:1027)
at com.inductiveautomation.ignition.gateway.SRContext.access$300(SRContext.java:277)
at com.inductiveautomation.ignition.gateway.SRContext$2.run(SRContext.java:741)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:546)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
Something is using the port that the Ignition OPC UA server is trying to bind to, maybe because shutdown was not clean and there’s another process hanging around or maybe legitimately some other software.
What Ignition and what Kepware versions?
