Hi!
I have a UDT (Short) coming from an OPC with 5 instances, I want to know if there is a way that I can view and manipulate the value coming from these UDT using only 1 template.
I have tried the indirect tags but is not working properly, is there any other way to do this?
Regards
Not sure what you mean by this. Do you mean you have a short data type opc tag within a udt definition that has 5 instances?
have you set the binding to bidirectional?
Yes, it is set as bidirectional, but is not working, is there another way to do this, like using expressions or something like that?
and to maintain
You didn't answer my first question, so I'm still in the dark a bit.
Can you post screenshots of your:
- tags
- component property binding
Hi!,
I have these UDT Tags and I want to modify the value with only one template, I am using a numeric text field but is not working as it should.
I am using the mode tag for choosing the property and change the value between the different instances.
@Gabriel_Villagran asking questions about the certification test in our forums is explicitly forbidden (page 2 of the test instructions). If you have questions about the test, please send them to training@inductiveautomation.com
