Does anyone know of a way to bulk bind the properties of a large list of tags or know how to have ignition do this automatically? Here is my scenario:
I have the UDT parameters built into the OPC item path within the JSON file
ns=1;s=[{GenNum}]{UnitId}.HRUI5574
Typically the OPC item path would be ns=1;s=[Gen 1]21.HRUI5574
But after importing the JSON file, the parameters are not bound to the OPC item path.
I thought that even if I only had to do this once, I could then export the JSON file for the UDT definition and then import that file for all future projects. This was not the case however.
I tried this for a single tag, exported the UDT definition with the binding active and got an error after trying to immediately import it back into ignition.
