Hello,
I am using Kepware to establish an OPC-UA connection to Ignition. The connection is valid, and standard opc tags brought over via the OPC browser work fine. However when trying to implement these tags within a UDT they aren’t working. I noticed that every time I create an instance of my UDT, I get an error when opening the instance “Structure contains invalid parent data types”. This is likely the issue here, but I can’t think of what would be causing this.
Any advice would be appreciated, thanks!
