I two UDT’s that are almost identical. The OPC address for some tags are slightly different between the two but one of the UDT’s works fine with no errors but the other gives me a warning anytime I update it. Has anyone seen this before? As far as I can tell looking at it, everything in the UDT is working like it should. The one identifier I see in the error is “Stage 1 Temp SP”. There are two tags in different folders that have that name. One of them is a memory tag, the other is an expression that pulls a value from a query tag. Both look like they are doing what they are supposed to be doing. I’m not sure where to go with this one. I don’t like leaving anything in a system that creates a warning or error even though it doesn’t appear to create any actual issues.
