I’m looking for a way to make a fully dynamic Item Path, but am having trouble with the last reference. I want to have each tag reference the folder name so when I copy/paste to add more folders, the tags update as well. This would save me a ton of time manually changing that last number to match the path for each instance.
You can control the way UDTs are created. i.e. 1-20 etc… If need be you can use a parameter in the UTD for binding to your path. Just have to make sure your structure is setup for it to go smoothly.
Did you find how to achieve that ?
