I want to generate a modbus address in the opcitempath using two parameters:
Base address: 40010 (this is the base address that I want to start with)
Instance: 2
The Computed Offset: Instance * 50
The resulting address should be: ns=2:s=chana.deva.40110@Float or ns=2:s=chana.deva.40160@Float for instance 3.
I have tried several iterations of the following opcitempath in the UDT tag
{channel}.{device}.{Base}+{Instance*50} Results: ns=2:s=chana.deva.40010+100@Float
{channel}.{device}.{{Base}+{Instance50}} Results: ns=2:s=chana.deva.{{Base}+{Instance50}}@Float
{channel}.{device}.{Base+{Instance50}} Results: ns=2:s=chana.deva.{Base+{Instance50}}@Float
{channel}.{device}.{{Instance50}+40010} Results: ns=2:s=chana.deva.{{Instance50}+40010}@Float
{channel}.{device}.{Instance*50}+40010 Results: ns=2:s=chana.deva.100+40010@Float
Does anyone have an idea how I can automatically generate the opcitempath using a Base address and an Instance without doing an override on the opcitempath? This will allow us to create a single UDT instead of dozens to poll each instance.
Thanks,
Greg E.
