Hi all,
I’m on 8.1.7 and I’m trying to access a UDT parameter as follows but I seem to be getting a null value:
siteName = tag[‘parameters’][‘SiteName’]
Is this right?
Hi all,
Is this right?
I’m doing that in some of my scripts, what you have should work. Dumb question, but do you have a value in that parameter? If you haven’t assigned a value yet, I think the parameter may be null rather than a string.
Otherwise, I found it beneficial to explicitly cast to my desired to my desired type. In your case:
siteName = str(tag[‘parameters’][‘SiteName’])
Hi Cory,
I think I figured out the issue, I had to define siteName outside my function.
