UDT Passing Parameters Error
I have a UDT in my Logix Designer, and I created a UDT definition with all of the tags in the UDT. Now I am following the "Custom UDT pass parameters" ignition video but when i click the button to go to the popup and pass the parameters over It errors and shows "Cannot assign orphaned UDT instance to a component property?"
I have tried everyone's suggestions I have seen online; any help is appreciated!
Try creating a new instance of the UDT and setting the parameters.
I got it figured out! What I have not seen anyone say (or videos) is that you need to go to the custom property inside the windows and TAG your UDT custom property with the INSTANCE of the UDT. and then the error goes away!
