Would I be correct in the assuming that an instance of UDT cannot use a different Tag History Provider than the one defined in the UDT?
We have lots of different “areas” in the plant that need to log hundreds of tags data to different databases, does this mean I would have to create a duplicate UDT with a different History provider for each database/area?
According to the documentation you can only parameterize a few things on a UDT, seems a bit of a limitation. I ran into something similar with the min/max Engineering limits, as far as I can see you cannot specify different min/max for instances either…
Perhaps I would be better with transaction manager for histroical data? perhaps there is some wizardry I am unaware of, I am pretty new to Ignition.
