I developed a project based off of the IU tutorials for creating a UDT Template found here:
inductiveuniversity.com/video/t … /templates
Using Ignition 7.8.2
The template parameter was set for drop-target so I could easily create instances on my display. I started with only two instances on my display, each bound to a separate UDT-type tag. The UDT structure has a few nested UDTs and the memory size for the entire structure is about 36Bytes. Each template instance passes the UDT as a parameter to subsequent popups for additional status and control (2-3 popups).
I tested my screens in the designer “Run” mode and experienced very poor performance; slow to respond, and even hanging the designer to the point the process needed to be killed.
IA Technical support informed me that UDT binding has significant overhead and that I should use indirect tag binding instead. I changed all bindings to indirect/expression and the performance issues were no longer a problem. I am a bit baffled by this, especially given that I had only two instances of the UDT, and the UDT is relatively small (36 bytes).
Some new information…
I removed a nested template that was also bound to a UDT and performance is good.
Scenario A (poor performance):
Template A (UDT, drop-target) is placed on Main Window
mouse-press on Template A opens Popup Window A
Popup Window A contains Template B
Template B contains an instance of Template A (same as on Main Window, but configured to disable any additional popup on mouse press)
Template A and B are both bound to the same UDT but Template B is bound to a custom property of Popup Window A, while Template A is bound to a custom property of Template B.
Scenario B (good performance)
Popup Window A contains Template B and an instance of Template A (same as on Main Window, but configured to disable any additional popup on mouse press)
Template A and B are both bound to the same UDT (the same custom property of Popup Window A)
Dan
