UDT Templates V8.0
With the improvements to the tag system in V8.0 is it still recommended to pass UDT tag paths as template parameters instead of the UDT tag itself?
I wouldn’t, because it precludes using multiple non-related UDTs with the same template, nor using a plain folder that mimics a UDT in special cases. It would be good to know if the performance hit for UDT properties has been fixed. Are you going to test this for us?
