Hello everybody.
We are using Ignition version 7.7.2 (b2014121709) with Java 1.8.0_25 running on Windows 7 64 bit and we are detecting a bug inside the Calendar Week View component.
Steps to reproduce the behavior:
(See also the attached screenshots)
Set at least two events, one of them must overtake the day. In my example “Task 1” starts Monday at 6:00 AM and stops Tuesday at 3:00 AM.
Click onto “Task 2“ for highlight it.
Click onto “Task 1” for highlight it. Doing so the problem happens: “Task 1” will be drawn only in the second column.
[color=#FF0000]Note: the problem happens only if you click on Tuesday.[/color]
[color=#FF0000]Note 2: if you add a third event starting on Saturday 14 and stopping on Sunday 15 the control won’t draw it.[/color]
I’ve installed the version 7.7.3 rc1.
I can confirm that “Note 2” was fixed.
Unfortunately the first issue still persists.
I’ve recorded a short video to show you the problem. Note that, as soon the issue arises, the color of the task change and it loose the alpha blending.
You can download the video here: https://www.cubbyusercontent.com/pli/Week%20View%20Bug.avi/_4435f2e6129e4fee916105163a323fd1
