Unable to add data to memory buffer, buffer full. DEC2023
Hello,
I have a long running gateway timer script that listens to a piece of equipment's 'event stream' and takes various action according to what the 'event steam' posts (e.g. the machine goes out of run mode). If the script fails, I have it throw and exception and post the error message to the logs before trying to start up again 30 seconds later. I have some other functionality in place that sms's me when the script stops and starts running.
The thing has been running fine for a long while now but yesterday (a Sunday) at ~11:30am, I started getting very frequent sms's for the alarm becoming active (that the script failed) and clearing (re-starting).
Error Message:
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 94, in File "", line 94, in at com.inductiveautomation.ignition.gateway.history.stores.MemoryStore.insertInBuffer(MemoryStore.java:186) at com.inductiveautomation.ignition.gateway.history.stores.MemoryStore.syncdStoreData(MemoryStore.java:84) at com.inductiveautomation.ignition.gateway.history.stores.AbstractStore.storeData(AbstractStore.java:233) at com.inductiveautomation.ignition.gateway.history.stores.MultiStageStore.syncdStoreData(MultiStageStore.java:144) at com.inductiveautomation.ignition.gateway.history.stores.AbstractStore.storeData(AbstractStore.java:233) at com.inductiveautomation.ignition.gateway.history.DefaultStoreAndForwardEngine.storeData(DefaultStoreAndForwardEngine.java:145) at com.inductiveautomation.ignition.gateway.history.HistoryManagerImpl.storeHistory(HistoryManagerImpl.java:261) at com.inductiveautomation.ignition.gateway.script.GatewayTagUtilities.storeTagHistoryImpl(GatewayTagUtilities.java:459) at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.storeTagHistory(AbstractTagUtilities.java:612) at jdk.internal.reflect.GeneratedMethodAccessor211.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) java.lang.Exception: java.lang.Exception: Unable to add data to memory buffer, buffer full.
at org.python.core.Py.JavaError(Py.java:547)
at org.python.core.Py.JavaError(Py.java:538)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:192)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
at org.python.core.PyObject.__call__(PyObject.java:512)
at org.python.core.PyObject.__call__(PyObject.java:517)
at org.python.pycode._pyx2218.f$0(:108)
at org.python.pycode._pyx2218.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1687)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:804)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runCode(ProjectScriptLifecycle.java:843)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:752)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runCode(ProjectScriptLifecycle.java:824)
at com.inductiveautomation.ignition.common.script.TimerScriptTask.run(TimerScriptTask.java:90)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: org.python.core.PyException: java.lang.Exception: java.lang.Exception: Unable to add data to memory buffer, buffer full.
... 22 common frames omitted
Caused by: java.lang.Exception: Unable to add data to memory buffer, buffer full.
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
... 19 common frames omitted
Line 94 of the script calls the Ignition system function to storeTagHistory:
system.tag.storeTagHistory(histProv, tagProv, paths, values)
If I comment that line out - the next time the script starts - it does not fail.
Interestingly, if I uncomment the line, I have observed that it doesn't fail on the same iteration of that line that is within an endless for loop - but is usually a short duration after the 600th loop (the first ~10000 event/loops happen within the first few seconds (downloading the equipment's current state) and then slows down to 1 event per second.
I searched the forum for issues related to this and took a look at my store and forward status for this database:
I have a support ticket in with our IT guys who report that there was a full system outage yesterday. I am still trying to get more information out of them in this regard.
I also intend on submitting a ticket to IA that will reference this post.
Look at the speed of entries into your memory buffer versus the speed of your database. Your database simply isn't keeping up with the workload. IA might be able to help you figure out why, but the DB is really your responsibility.
Thanks Phil, that screen shot was even taken when I had the line of code to store to database commented out so I think your on to something. Why this all of a sudden started being an issue on a Sunday when no-one is making changes within Ignition makes me think it is IT related.
