Hello Team,
We are trying to connect Smart Relay(FL1F-H12RC) over Modbus TCP connection, We are unable to connect to Smart Relay(FL1F-H12RC) over Modbus TCP & getting below error on gateway log.
We are currently trying to connect to an IDEC Smart Relay (FL1F-H12RCE) over Modbus TCP using Ignition and we are not being successful either. Wondering if you had any luck communication with the Smart Relay over Modbus TCP using ignition? I am starting to think that IDEC Smart Relay is able to communicate over Modbus TCP with other IDEC Smart Relays only.
I would guess that Ignition's default to unit #0 is the problem. Based on the address map I just downloaded, which indicates one-based addressing, try these OPC Item Paths (direct in a tag, not in the address mapper):
