Unable to connect with database connection in Ignition after upgrade 8.1.26 to 8.143
Getting the below error in Database connection in Ignition after upgrade 8.1.26 to 8.143
java.sql.SQLException: Cannot create PoolableConnectionFactory (The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "No appropriate protocol (protocol is disabled or cipher suites are inappropriate)".)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:656)
at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:534)
at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:734)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:300)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:253)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.lambda$newRetryRunnable$0(DatasourceManagerImpl.java:1097)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:593)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "No appropriate protocol (protocol is disabled or cipher suites are inappropriate)".
at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:1368)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1412)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:1058)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:833)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:716)
at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:841)
at org.apache.commons.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:52)
at org.apache.commons.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:357)
at org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:103)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:652)
... 12 more
Caused by: javax.net.ssl.SSLHandshakeException: No appropriate protocol (protocol is disabled or cipher suites are inappropriate)
at java.base/sun.security.ssl.HandshakeContext.(Unknown Source)
at java.base/sun.security.ssl.ClientHandshakeContext.(Unknown Source)
at java.base/sun.security.ssl.TransportContext.kickstart(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1379)
... 20 more
8.1.43 (b2024082010)
Azul Systems, Inc. 17.0.11
This usually means you're connecting to a very old version of SQL Server that doesn't support TLS 1.2 or later...
I think this KB article covers it, but if not you can find other posts on the forum about it as well: https://support.inductiveautomation.com/hc/en-us/articles/4417310204813-TLS-v1-0-and-v1-1-Microsoft-SQL-Server-Database-connection-issue
Please see Wiki - how to post code on this forum (and error logs). When you format it as code the forum automatically limits the number of lines displayed (and adds a scrollbar) so that the post doesn't become ridiculously long. You can edit your post to fix it. Thanks.
If you've got an ancient version of SQLServer then try the approach listed starting at this post: SQL Express 2005 database connection ideas? - #15 by JordanCClark and read down to the end.
Or maybe time to upgrade sql server :slight_smile:
In my case it was on a validated medical device manufacturing machine. Revalidation would have been a major pain.
Oooh - it was running on XP too!
