Unable to create folder path, found non-folder in the way at 'ignition/named-query'
found error when creating named query in designer. can anyone help on this
java.lang.IllegalArgumentException: Unable to create folder path, found non-folder in the way at ‘ignition/named-query’
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.insertFolders(DesignerProjectTreeImpl.java:244)
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.createResourceInternal(DesignerProjectTreeImpl.java:210)
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.createResource(DesignerProjectTreeImpl.java:196)
at com.inductiveautomation.ignition.designer.project.CreateResourceDialog$CreateAction.actionPerformed(CreateResourceDialog.java:146)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Ignition v8.0.16 (b2020082513)
Java: Azul Systems, Inc. 11.0.7
You need to take a look at the tree structure of the files on disk. Go to your gateway, and then the Ignition installation directory.
Start at /data/projects/${your project name}/ignition/named-query - follow the folder structure from there.
The actual path after the named-query/ folder should map to the path in your project, ending in a folder with the same name as your actual resource(s); inside that should be at minimum a resource.json and a data.bin file.
Dear @paul-griffith,
I was checked file in named-query folder. there are two file in it as mention in reply. but still same error we getting. do needful.
If your situation is urgent, you should open a support ticket and get them to look over your shoulder.
