Currently I'm facing an issue with opening the Prespective View.
I'm Currently using Designer V8.1.43, Kindly help me to recovery in the designer.
Regards,
Sesha
Don't worry yet. I have seen that before. There must be something corrupt in the json view. This json can the modified and "recover" the view. Share the json and recall what was the last change you did that lead to that error.
doesn't make sense, 151 KB for an empty file?
try this, on the designer. Ctrl+Shift and right click on the view from the project property tree. select copy json and share.
Are you trying to store a binary or a very large string on the view? Try to delete all the value of that item.
When edited paste the json on an empty view with the same container type as the source view.
I don't think so. I just started grahic design in Tab Container, I didn't tag bind nothing it's just grahic of tanks and few faceplate Template motor and valve.
It looks like the JSON view got corrupted while designing. Try exporting the JSON, removing any large or broken data, and then importing it into a new view with the same type. If that doesn’t work, you might need to restore from a backup or reach out to support for help.
I also believe 8.1.44 has a fix for this to try to prevent this from happening in the future. You might want to upgrade if possible.
