Unable to Disable Default setting of Tag Browser > Scripting > Value events > Settings
Hi Support Team,
Requirement
We need to configure Ignition Edge to capture and forward tag values with unchanged values but updated timestamps to the cloud. This will help us:
To Ensure we receive tag values with updated timestamps.
To Plot a continuous graph in our front-end visualization.
Exploration and Issue
  • We explored various options and reviewed the documentation.
  • Disabling the setting under Tag Browser > Scripting > Value Events seems to be a potential solution.
  • However, this setting is not being saved when we disable the default.
Request for Assistance
Please suggest how we can configure Ignition Edge to:
  • Ensure the Tag Browser forwards tag values to the MQTT transmitter when there is only a timestamp change but no value change.
Current Setup/Behavior
  • Ignition Edge only sends tag values to the MQTT transmitter when there is a value change.
Desired Behavior
  • Ignition Edge also sends tag values to the MQTT transmitter when there is a timestamp change, regardless of value change.
Ignition Edge Version: 8.1.17
Thank you.
Hello and welcome,
This is not support. It's a user forum. Support is over there.
