Unable to find valid certification path to requested target caused by SSLHandshake Exception while trying to get data from API endpoint
I am trying to get data from an API endpoint of opcenter. While running the script I am getting the error
"caused by IOException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target"
I have installed the certificate and placed it in folder "C:\Program Files\Inductive Automation\Ignition\data\certificates\supplemental" . I have attached the code as well
url = "......................."
headers = {
    'Authorization': 'Bearer ****** '
myClient = system.net.httpClient()
response = myClient.get(url,headers)
print response.getText()
Thank you
Your server certificate may be self-signed or signed by an internal CA, and you might need to add that certificate or CA to Ignition's trust store.
https://docs.inductiveautomation.com/display/DOC81/Security+Certificates#SecurityCertificates-AddingSecurityCertificatesintoKeyStores
Please feel free to reach out to support at support@inductiveautomation.com if you need additional assistance.
