Hey there
I downloaded the SDK and ran through the associated instructions with getting the SDK setup. I haven’t modified the existing code, and thought I’d see if I can get an example working. I have got a developer key in the Ignition System.
I went to the build of the ComponentExample and ran the Ant build, without any errors. I checked the Gateway and the module was loaded there, with a big green tick telling me that the module was loaded (not running
). When I try to load the Designer, I get an error:
Error Launching application
Exception: Error unpacking componentexample-designer.jar
I have tried restarting the gateway and the PC, but nothing happens. I have tried other examples in the SDK and I get the same error.
Where can I find more information about this error, where will this log be recorded? What do I need to do in order to use these example modules?
Regards
Jarren
Hi Carl
- When I run the “java -version” command I get:
Java SE runtime environment (build 1.8.0-b132)
I am running a 32-bit version of Java on a 64-bit Windows 8 machine, if that makes any difference.
No other details other than the text I have written below. It appears in a pop-up window, if that is relevant. Is there not a log that may reveal more information?
Pack200.properties, as viewed by Notepad++:
modificationtime=latest
stripdebug=false
deflatehint=true
keepfileorder=false
unknownattribute=error
segmentlimit=-1
effort=7
com.sun.java.util.jar.pack.package.majver=150
com.sun.java.util.jar.pack.package.minver=7
Regards
Jarren
Remove the last two lines of pack200.properties.
They’re not compatible with Java 8.
Same problem with during opening Designer:
[color=#FF0000]Error launching application:
[/color]
Regarding your checks:
- What version of Java are you running?
Java version “1.6.0_45”
- Are there any more details in that error message?
No more detail, pop-up during opening Designer.
- What does your pack200.properties file look like in your SDK’s build directory?
[color=#800080]modificationtime=latest
stripdebug=false
deflatehint=true
keepfileorder=false
segmentlimit=-1
effort=7
[/color]
I try with and without the lines
[color=#800080]com.sun.java.util.jar.pack.package.majver=150
com.sun.java.util.jar.pack.package.minver=7[/color]
(see built.txt)
Same Error.
Ok, I found.
There was a file “componentexample-designer.jar.pack.gz” in the folder " Ignition\lib\core\designer"
After removing this file, all works without problem.
