Unable to get IdP with name 'AD_internal_hybrid' from cache
Version: 8.1.22.
We're picking through the status log errors and have made good progress in weeding out many of them. I've had five occurrances of Unable to get IdP with name 'AD_internal_hybrid' from cache over the past three days but by various projects. I think the IdP is working OK because login is working correctly on our Perspective applications.
IdP error log properties
and the log details - for what they're worth:
Log details
java.util.concurrent.ExecutionException: com.inductiveautomation.ignition.gateway.auth.idp.NotFoundException
at com.google.common.util.concurrent.AbstractFuture.getDoneValue(AbstractFuture.java:531)
at com.google.common.util.concurrent.AbstractFuture.get(AbstractFuture.java:492)
at com.google.common.util.concurrent.AbstractFuture$TrustedFuture.get(AbstractFuture.java:83)
at com.google.common.util.concurrent.Uninterruptibles.getUninterruptibly(Uninterruptibles.java:196)
at com.google.common.cache.LocalCache$Segment.getAndRecordStats(LocalCache.java:2312)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2278)
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2154)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2044)
at com.google.common.cache.LocalCache.get(LocalCache.java:3952)
at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3974)
at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4958)
at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterManagerImpl.getIdpAdapter(IdpAdapterManagerImpl.java:704)
at java.base/java.util.Optional.flatMap(Unknown Source)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.startupInternal(WebAuthSessionImpl.java:121)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.mdc(WebAuthSessionImpl.java:102)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.startup(WebAuthSessionImpl.java:128)
at com.inductiveautomation.perspective.gateway.session.SecuredPerspectiveProjectSession.onStartupInternal(SecuredPerspectiveProjectSession.java:604)
at com.inductiveautomation.perspective.gateway.session.SessionKernelWrapper.onStartup(SessionKernelWrapper.java:145)
at com.inductiveautomation.ignition.common.lifecycle.AbstractLifecycle.startup(AbstractLifecycle.java:18)
at com.inductiveautomation.ignition.common.util.ExecutionQueue$FragileRunnableFuture.getValue(ExecutionQueue.java:286)
at com.inductiveautomation.ignition.common.util.ExecutionQueue$FragileRunnableFuture.getValue(ExecutionQueue.java:275)
at com.inductiveautomation.ignition.common.util.ExecutionQueue$FragileCompletableFuture.run(ExecutionQueue.java:266)
at com.inductiveautomation.ignition.common.util.TimedRunnable.run(TimedRunnable.java:21)
at com.inductiveautomation.ignition.common.util.ExecutionQueue$PollAndExecute.run(ExecutionQueue.java:239)
Caused by: com.inductiveautomation.ignition.gateway.auth.idp.NotFoundException: null
at java.base/java.util.Optional.orElseThrow(Unknown Source)
at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterManagerImpl$IdpAdapterCacheLoader.load(IdpAdapterManagerImpl.java:153)
at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterManagerImpl$IdpAdapterCacheLoader.load(IdpAdapterManagerImpl.java:147)
at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3528)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2277)
... 21 common frames omitted
Any suggestions about what is causing this? Is it an Active Directory timeout external to Ignition?
If you look in the internal database, specifically the IDP_ADAPTERS table, do you see a record with the called out name? There's not a lot of pieces that could fail to cause this error; it's basically: retrieve all the records, put them into a Map<String, IdpAdapter>, then retrieve by name. That retrieval by name is what's failing.
Thanks, Paul. Can you remind me how to access the internal database? (I think I looked into it a couple of years ago but have no idea how.)
From any page in the status section, change the trailing url the "sys.internaldb". Or use the Konami code. Or use Kindling, or any other SQLite browser, on a GWBK.
Making progress ...
What next? (Thanks for the hand-holding.)
Hmm, the binary data should just be a JSON strings, I'm not sure how best to coerce it out. Probably have to Google a SQLite conversion function so that the IDB page doesn't think it's binary data anymore.
Ha!
SELECT idp_adapters_id, json_extract(config, '$') FROM idp_adapters
returns four items. The one I think is relevant is #3:
IdP_Adapters_Id JSON
	"name": "IdP_AD_internal_hybrid",
	"description": "Automatically generated Ignition Identity Provider which uses the User Source Profile named \"AD internal hybrid\".",
	"authStrategy": {
		"type": "ignition",
		"config": {
			"version": 1,
			"userSource": "AD internal hybrid",
			"authMethods": ["username-and-password"],
			"defaultAuthMethod": "username-and-password",
			"badgeSecret": false,
			"sessionInactivityTimeout": 30,
			"sessionExp": 0,
			"rememberMeExp": 0
	"userAttributeMapper": {
		"id": {
			"type": "direct",
			"config": {
				"attributePath": "sub"
		"userName": {
			"type": "direct",
			"config": {
				"attributePath": "preferred_username"
		"firstName": {
			"type": "direct",
			"config": {
				"attributePath": "given_name"
		"lastName": {
			"type": "direct",
			"config": {
				"attributePath": "family_name"
		"email": {
			"type": "direct",
			"config": {
				"attributePath": "email"
		"roles": {
			"type": "direct",
			"config": {
				"attributePath": "roles"
	"directSecurityLevelPolicies": {
		"id": {},
		"username": {}
	"derivedSecurityLevelPolicies": []
I don't see any problem there? Anyone?
Well, that's not the same as AD_internal_hybrid, which is what's apparently being requested...
I don't see anything suggesting there's any automatic addition of a prefix or anything.
Well spotted. The list is:
  • temp
  • IdP_AD_internal_hybrid
  • opcua_module
  • default
Meanwhile Config | SECURITY | Identity Providers shows,
Check the project's properties? Does it have a stale reference? Is the project IdP configured in Project Properties -> General, or Project Properties -> Perspective -> General? The latter path is deprecated for some legacy reasons, and once you make a change in the former, the latter should be automatically hidden.
The project IdP is configured in both Project Properties | General and in Project Properties | Perspective | General. Changing the former to or default and applying the change didn't hide the latter.
I'll investigate more tomorrow. Thank you again for the follow through.
Duh! And save the project to update the gateway.
I think we may have solved the problem.
