I booted up Ignition one day to start working. I logged in successfully to the designer and got to the screen where you select a project. However, when I tried to load a project, it would give me this error:
[quote]LookupError: no codec search functions registered: can’t find encoding ‘utf-8’
Ignition v7.7.2 (b2014121709)
Java: Oracle Corporation 1.8.0_60[/quote]
I’ve tried re-installing Java, updating to the latest version available to me, and looked all around the internet but I’ve been unable to fix this issue. All I know is that no projects will load, from the designer or from the Gateway directly running as a client. None of my coworkers have had this issue, and our laptops are all standardized.
I have 2 questions:
A: Is there something I did to cause this that I should avoid, or did it just sorta happen (This one is less important)
B: How do I fix this so I can get back to work? (This one is extremely important)
