We are unable to open a window in Launch Designer. The project is recently restored into Ignition Gateway. All other windows can be opened, except this one.
[color=#FF0000]
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error deserializing element “” on line 2078
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$Parser.wrapException(XMLDeserializer.java:460)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$Parser.endElement(XMLDeserializer.java:478)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer._deserialize(XMLDeserializer.java:201)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:164)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:160)
at com.inductiveautomation.factorypmi.application.model.WindowCache._deserializeWindow(WindowCache.java:275)
at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:217)
at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:430)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$DesigntimeWindowOpener.openWindow(WindowWorkspace.java:2401)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openWindow(WindowWorkspace.java:814)
at com.inductiveautomation.factorypmi.designer.model.navtree.WindowNode.onDoubleClick(WindowNode.java:472)
at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$MouseListener$1.run(NavTreePanel.java:513)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
Caused by: java.lang.NoSuchMethodException: com.inductiveautomation.factorypmi.application.components.PMITable.setHeaderFont(java.awt.Font)
at java.lang.Class.getMethod(Unknown Source)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endSubElement(ObjectDeserializationHandler.java:66)
at com.inductiveautomation.factorypmi.application.xmlserialization.ComponentDeserializationHandler.endSubElement(ComponentDeserializationHandler.java:84)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$Parser.endElement(XMLDeserializer.java:475)
… 34 more
Ignition v7.2.5 (b76)
Java: Sun Microsystems Inc. 1.6.0_30
[/color]
Please give me a suggestion
