Unable to open project in designer after upgrade from 8.0 to 8.0.1
So I have a project that opens fine in a vision client after upgrading, but won't open in designer. The error report I'm getting is:
java.lang.IllegalArgumentException: Cannot add child named 'TextScript', name in use.
at com.inductiveautomation.ignition.designer.project.ResourceTreeNode.addChildInternal(ResourceTreeNode.java:243)
at java.base/java.util.ArrayList.forEach(Unknown Source)
at com.inductiveautomation.ignition.designer.project.ResourceTreeNode.(ResourceTreeNode.java:57)
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.createNode(DesignerProjectTreeImpl.java:141)
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.lambda$createNode$7(DesignerProjectTreeImpl.java:138)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
at java.base/java.util.HashMap$KeySpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.collect(Unknown Source)
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.createNode(DesignerProjectTreeImpl.java:139)
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.lambda$new$0(DesignerProjectTreeImpl.java:71)
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.(DesignerProjectTreeImpl.java:72)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler.lambda$new$2(IgnitionDesigner.java:1891)
Ignition v8.0.1 (b2019050708)
Java: Azul Systems, Inc. 11.0.2
Resolved this from downgrading from 8.0.1 to 8.0. After this, the same project opens fine.
Can you send in or upload a project export or .gwbk? Or send it in to support?
