I was modifying a window and added a Multistate Indicator. I modified the Styles dataset table and removed all of the default columns except 'state' and 'text' (animationindex, animation Duration, backgorund, border, foreground). I started receiveing the following error popup every time I attempted to modify this object. I tried deleting the object and received the same error. I closed the window and saved the project. Now when I attempt to open the window, I get this error and the window does not open. I am no longer able to modify this window because it will not open. Exporting the window and importing it does not clear the error. Any ideas for a workaround? Thanks.
Following is the error:
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error invoking [PMIMultiStateIndicator]Multi-State Indicator.setStyles(Dataset [2R ⅹ 2C])
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endSubElement(ObjectDeserializationHandler.java:81)
at com.inductiveautomation.factorypmi.application.xmlserialization.ComponentDeserializationHandler.endSubElement(ComponentDeserializationHandler.java:93)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementEnd(XMLDeserializer.java:663)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:165)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:313)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:233)
at com.inductiveautomation.factorypmi.application.model.WindowCache._deserializeWindow(WindowCache.java:277)
at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:216)
at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:435)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$DesigntimeWindowOpener.openWindow(WindowWorkspace.java:3325)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openWindow(WindowWorkspace.java:1078)
at com.inductiveautomation.factorypmi.designer.workspace.StartupPanel$ResourceThumbnail.onClick(StartupPanel.java:335)
at com.inductiveautomation.factorypmi.designer.workspace.StartupPanel$ThumbnailButton$1.mouseClicked(StartupPanel.java:242)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endSubElement(ObjectDeserializationHandler.java:68)
... 56 more
Caused by: java.lang.ArrayIndexOutOfBoundsException: -1
at com.inductiveautomation.ignition.common.BasicDataset.getValueAt(BasicDataset.java:114)
at com.inductiveautomation.factorypmi.application.binding.StyleListener.register(StyleListener.java:218)
at com.inductiveautomation.factorypmi.application.binding.StyleListener.propertyChange(StyleListener.java:105)
at java.beans.PropertyChangeSupport.fire(Unknown Source)
at java.beans.PropertyChangeSupport.firePropertyChange(Unknown Source)
at java.awt.Component.firePropertyChange(Unknown Source)
at com.inductiveautomation.factorypmi.application.components.PMILabel.setStyles(PMILabel.java:345)
... 61 more
Ignition v7.6.4 (b2013112117)
Java: Oracle Corporation 1.7.0_51
