Hello, I an unable to open one window in vision. It pops up this: "SerializationException: Error deserializing element ""
caused by IllegalArgumentException: Start point cannot equal endpoint"
Any help with this would be greatly appreciated.
Can you provide the full error / stack trace if there is one? There's usually a lot more error information available.
That said, this is usually the kind of thing you need to open a ticket with support for. They can take your gateway backup / project export / window export / etc... and try to "rescue" the window if necessary.
Not for sure if this is what you were looking for, but this is from the copy error button:
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error deserializing element ""
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.createException(XMLDeserializer.java:1005)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.createException(XMLDeserializer.java:966)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementEnd(XMLDeserializer.java:935)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:165)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:367)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:277)
at com.inductiveautomation.factorypmi.application.model.WindowCache._deserializeWindow(WindowCache.java:387)
at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:330)
at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:304)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$DesigntimeWindowOpener.openWindow(WindowWorkspace.java:3867)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openWindow(WindowWorkspace.java:1528)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$4.lambda$createPanels$2(WindowWorkspace.java:630)
at com.inductiveautomation.ignition.designer.workspacewelcome.RecentlyModifiedTilePanel$Tile.lambda$new$1(RecentlyModifiedTilePanel.java:206)
at com.inductiveautomation.ignition.client.util.gui.Listen$1.mousePressed(Listen.java:52)
at java.desktop/java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: java.lang.IllegalArgumentException: Start point cannot equal endpoint
at com.inductiveautomation.ignition.client.util.gui.paints.RelativeLinearGradientPaint.(RelativeLinearGradientPaint.java:99)
at com.inductiveautomation.ignition.client.util.gui.paints.RelativeLinearGradientPaint.(RelativeLinearGradientPaint.java:54)
at jdk.internal.reflect.GeneratedConstructorAccessor64.newInstance(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endSubElement(ObjectDeserializationHandler.java:65)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementEnd(XMLDeserializer.java:932)
... 54 more
Ignition v8.1.31 (b2023081007)
Java: Azul Systems, Inc. 11.0.18
Yes, this has the additional info necessary.
Unfortunately you will have to contact support to get this window "rescued" or at least get a bug ticket open.
Thank you for you help!
