Has anyone ever run into this?
I cannot open a window even in designer because I am missing a component that is on that window (Busy Label). If I try to add it, it does not appear that anything changes. This all started when I upgraded ignition.
Thanks in advance!
If the component comes from an add-on module, you may need a new version of that module.
What happens when I cannot find a newer version? I can see the window when I hover over it (preview).
Did you install this module?
inductiveautomation.com/forum/v … 10325&f=88
Maybe ask him to update the module.
It may work. In the meantime I had an older version on another computer. I removed the component and imported back! Thanks for the help!
