Unable to open windows java.io.EOFException
I’m working on a project, I noticed that the image in the foreground of the page I was modyfing disappeared so I closed the designer hopying it would fix itself, but it got worse. I reopened the project and now I can’t open the main window, the error is:
	at java.base/java.util.zip.GZIPInputStream.readUByte(Unknown Source)
	at java.base/java.util.zip.GZIPInputStream.readUShort(Unknown Source)
	at java.base/java.util.zip.GZIPInputStream.readHeader(Unknown Source)
	at java.base/java.util.zip.GZIPInputStream.<init>(Unknown Source)
	at com.inductiveautomation.factorypmi.application.model.WindowInfo.getInputStream(WindowInfo.java:145)
	at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:310)
	at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:289)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$DesigntimeWindowOpener.openWindow(WindowWorkspace.java:3500)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openWindow(WindowWorkspace.java:1294)
	at com.inductiveautomation.factorypmi.designer.model.navtree.WindowNode.open(WindowNode.java:268)
	at com.inductiveautomation.ignition.designer.navtree.model.AbstractResourceNavTreeNode.onDoubleClick(AbstractResourceNavTreeNode.java:257)
	at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$MouseListener.lambda$mousePressed$0(NavTreePanel.java:655)
Ignition v8.0.2 (b2019060511)
Java: Azul Systems, Inc. 11.0.3
I exported the window but the bin file is empty.
I hope you can help me.
Daniele
That’s probably not good. Do you have a recent backup you can restore this window from? Support may be able to help you figure that out and restore only the window rather than everything else.
You should definitely upgrade to the latest 8.0 or 8.1 release if possible. The earlier 8.0.x releases had a variety of issues that sound similar to this.
I have an old backup, I guess I will learn from this mistake to make them more frequently.
The gateway I’m working has 8.0.2 istalled, I will upgrade it.
How can I just import the window? I have second gateway where I can restore the last backup and then export the window, then I just need to delete the window on the primary gateway and import it right?
That should work as long as the backup has a still valid copy of the window, though if you have trouble deleting it from the Designer for some reason you might need to drop to the filesystem to do it instead.
