Hi guys,
I hope you are doing well.
Anyone knows why my client window does not show the close, maximize and minimize icons. I need them to test the application out in different monitors but it does not allow me to move the window from my laptop screen to another device.
I tried to change some client setting from "Properties" section in the Designer.
May you please help me with this issue?
Best regards.
In v7.9, IIRC, full screen mode is always full screen, and is not equivalent at all to maximized. Change your default launch mode to windowed to be able to move the client around.
(I use Linux clients, and they provide UI methods to move even the full screen clients to different monitors, so I've never seen your precise problem.)
Thank you for you help, at the end, I just deleted the Client's application and then just downloaded it back and it's working.
