Dear Technical Support Team,
I am experiencing an issue in Ignition Perspective v8.3.2 where I am unable to save the Session Props configuration.
Issue Description:
- Unable to save changes made to Session Props.
- The save operation does not complete successfully.
- This issue is preventing further configuration and testing of the Perspective project.
Environment:
- Ignition Version: 8.3.2
- Perspective Module: Installed
- Operating System: Windows
- Java Version: Azul JDK 17 (if applicable)
Troubleshooting Performed:
- Created a new project and a new view.
- Restarted the Ignition Gateway.
- Verified that the Perspective module is installed and the Gateway is running.
- The issue still persists.
Could you please assist in identifying the root cause of this issue? Kindly let me know:
- The possible reason why Session Props cannot be saved.
- Whether this is a known issue with Ignition Perspective v8.3.2.
- Any recommended troubleshooting steps or patches to resolve the problem.
If required, I can provide the Gateway logs, Designer logs, screenshots, and any additional information that may help with the investigation.
Your prompt assistance would be greatly appreciated.
Thank you.
Best regards,
Error.txt (3.5 KB)
Sureshkumar Mani
