there is a problem with Tag historian. When I create a tag, for example memory Tag A , and then configure the tag history parameter, and store the Tag history in DB , the rest of parameters keep default. (DB has been connected in Gateway configuration). I changed the Tag A’s Value to see how it stored in DB.
So I wen to Tools> Database QueryBrowser>history table. But I did not found the Tag A column.
Any insight would be appreciated! Thanks!
