Hello,
I am trying to get started with Ignition and having trouble to get the designer to start. Following the getting started guide here, I face issues when I try and download and run the Designer launcher. I start the ignition server, download the Designer using the “Get Designer” button in the UI and then when I click “Open Designer” in the Designer Launcher, a pop up box (see below) will repeatedly pop up, progress to 100%, disappear and then come back. This happens indefinitely. I have poked around the forum and deleted the cache in the .ignition directory as recommended in some threads but that did not help. I have also inspected the logs in the clientlauncher.log file but don’t see anything out of the ordinary.
Any ideas? Thanks!
In the log files the launcher should log the full command it uses to launch the designer. Can you copy/paste that into a terminal and run it and then attach the full output here?
(something like in this post)
Here is the output:
/local/home/USERNAME/applications/ignition/designerlauncher/runtime/bin/java -classpath /home/USERNAME/.ignition/cache/resources/platform/launchclient.jar/00000000EEAE8D26/launchclient.jar -Djavaws.sr.gateway.addr.0=http://IP_ADDRESS:8088 -Djavaws.sr.launchts=1657661704800 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx4096M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=4096M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Dsun.awt.fontconfig=/local/home/USERNAME/applications/ignition/designerlauncher/runtime/conf/fonts/fontconfig.condensed.properties -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
Starting Bootstrap Loader v3.0
sun.awt.image.PNGImageDecoder$PNGException: crc corruption
at java.desktop/sun.awt.image.PNGImageDecoder.getChunk(PNGImageDecoder.java:718)
at java.desktop/sun.awt.image.PNGImageDecoder.getData(PNGImageDecoder.java:726)
at java.desktop/sun.awt.image.PNGImageDecoder.produceImage(PNGImageDecoder.java:253)
at java.desktop/sun.awt.image.InputStreamImageSource.doFetch(InputStreamImageSource.java:269)
at java.desktop/sun.awt.image.ImageFetcher.fetchloop(ImageFetcher.java:212)
at java.desktop/sun.awt.image.ImageFetcher.run(ImageFetcher.java:176)
Connect Step [attempt 1] connecting to: http://IP_ADDRESS:8088...
Downloading manifest at http://IP_ADDRESS:8088/system/launchmf/D?os=linux&arch=x64
...connect successful
Successfully downloaded launch manifest:
<?xml version="1.0" encoding="UTF-8"?>
<launch scope="D" framework="7" jreVersion="11.0.15" useCondensedDialogFont="true">
<module name="" build="2022061518">
<jar name="jide-shortcut-3.7.4.jar" crc="69D867D1" length="80404"/>
<jar name="jide-dock-3.7.4.jar" crc="5A8E7A8" length="383828"/>
<jar name="miglayout-core-4.2.jar" crc="FEECEF57" length="66663"/>
<jar name="jyiconfonts-3.4.0.jar" crc="D1221784" length="1142774"/>
<jar name="timingframework-1.0.jar" crc="7832C4C0" length="102616"/>
<jar name="commons-collections4-4.4.jar" crc="6847F0D3" length="751914"/>
<jar name="jose4j-0.7.2.jar" crc="5975173E" length="265782"/>
<jar name="common.jar" crc="BAA4D082" length="3750066"/>
<jar name="jul-to-slf4j-1.7.26.jar" crc="BF2AD0D0" length="4589"/>
<jar name="commons-lang3-3.11.jar" crc="4FD4C07C" length="577742"/>
<jar name="xmlgraphics-commons-2.3.jar" crc="CAE5A1BA" length="671727"/>
<jar name="imageio-core-3.4.1.jar" crc="B2745841" length="72506"/>
<jar name="poi-ooxml-4.1.1.jar" crc="5C3A1400" length="1859884"/>
<jar name="imageio-batik-3.4.1.jar" crc="170253E4" length="19374"/>
<jar name="rhino-1.7.6.jar" crc="7D1D24AD" length="1188593"/>
<jar name="bcprov-jdk15on-1.69.jar" crc="A76F4870" length="5743920"/>
<jar name="common-image-3.4.1.jar" crc="32B2CC13" length="86066"/>
<jar name="bcutil-jdk15on-1.69.jar" crc="76A0656E" length="359496"/>
<jar name="jxbrowser-swing-7.12.1.jar" crc="A75EF1E7" length="141749"/>
<jar name="swingx-0.0.3-ia.jar" crc="65E602E1" length="1512564"/>
<jar name="cron4j-2.2.5.jar" crc="FFAC5F7B" length="36227"/>
<jar name="curvesapi-1.06.jar" crc="D1B9BE33" length="111875"/>
<jar name="slf4j-api-1.7.26.jar" crc="A71DAC84" length="41139"/>
<jar name="designer-8.1.18.jar" crc="4095AF4F" length="13505456"/>
<jar name="kotlin-stdlib-jdk8-1.5.31.jar" crc="BC25B1B7" length="16121"/>
<jar name="jgrapht-core-1.4.0.jar" crc="AB8E765E" length="1091677"/>
<jar name="commons-compress-1.19.jar" crc="19AE5191" length="615064"/>
<jar name="kotlin-stdlib-common-1.5.31.jar" crc="4DB332A5" length="198322"/>
<jar name="ia-gson-2.8.5.jar" crc="7F980716" length="261492"/>
<jar name="forms-1.0.7.jar" crc="5E8CB029" length="86828"/>
<jar name="poi-ooxml-schemas-4.1.1.jar" crc="8F7A32A" length="7884238"/>
<jar name="bcpkix-jdk15on-1.69.jar" crc="15FDAC12" length="909020"/>
<jar name="batik-swing-1.12.jar" crc="B83D4C3E" length="190772"/>
<jar name="jide-common-3.7.4.jar" crc="DC3DB1B" length="1632900"/>
<jar name="log4j-over-slf4j-1.7.26.jar" crc="5296FF81" length="23650"/>
<jar name="joda-time-2.10.2.jar" crc="EE76ABA0" length="642711"/>
<jar name="kotlinx-coroutines-core-jvm-1.5.2.jar" crc="1FB63442" length="1481065"/>
<jar name="batik-awt-util-1.12.jar" crc="4CEB277F" length="422448"/>
<jar name="batik-util-1.12.jar" crc="F09002E9" length="127209"/>
<jar name="logback-classic-1.2.3.jar" crc="6407A406" length="290339"/>
<jar name="autocomplete-3.2.0.jar" crc="F24C7053" length="154205"/>
<jar name="kotlinx-coroutines-swing-1.5.2.jar" crc="DDF67DE4" length="9331"/>
<jar name="rsyntaxtextarea-3.2.0.jar" crc="2F8C0BFE" length="1248250"/>
<jar name="client-api-8.1.18.jar" crc="CE7AA2F7" length="3178236"/>
<jar name="batik-script-1.12.jar" crc="73865109" length="25715"/>
<jar name="commons-codec-1.13.jar" crc="1F1614BB" length="344339"/>
<jar name="commons-math3-3.6.1.jar" crc="5D5A24E1" length="2213560"/>
<jar name="jywidgets-3.4.0.jar" crc="BC77AAE5" length="552228"/>
<jar name="batik-bridge-1.12.jar" crc="7F6DB498" length="695968"/>
<jar name="java-cup-10k.jar" crc="3FCB2D3D" length="84156"/>
<jar name="rstaui-3.2.0.jar" crc="F94283C0" length="121343"/>
<jar name="jide-dialogs-3.7.4.jar" crc="73B908E3" length="60097"/>
<jar name="synthetica-addons-3.4.0.jar" crc="7930C92B" length="296003"/>
<jar name="commons-logging-1.2.jar" crc="3621FD43" length="61829"/>
<jar name="guava-26.0-jre.jar" crc="47C422DD" length="2740721"/>
<jar name="batik-gvt-1.12.jar" crc="83F7136" length="191437"/>
<jar name="commons-text-1.9.jar" crc="89FA2468" length="216211"/>
<jar name="jxbrowser-7.12.1.jar" crc="8B8D0FBE" length="9877025"/>
<jar name="common-lang-3.4.1.jar" crc="1C5480E4" length="121090"/>
<jar name="client-bootstrap-8.1.18.jar" crc="E720BEE1" length="4028443"/>
<jar name="poi-4.1.1.jar" crc="5964EDEF" length="2827712"/>
<jar name="batik-css-1.12.jar" crc="CD9AE2F4" length="325399"/>
<jar name="batik-dom-1.12.jar" crc="E51605CA" length="182590"/>
<jar name="batik-xml-1.12.jar" crc="10A9F179" length="33497"/>
<jar name="kotlin-stdlib-1.5.31.jar" crc="8C0FD528" length="1505952"/>
<jar name="kotlin-stdlib-jdk7-1.5.31.jar" crc="CDCCB4BF" length="22986"/>
<jar name="languagesupport-3.1.4.jar" crc="51FCE7E9" length="1132674"/>
<jar name="jfreechart-min-1.0.0.jar" crc="DC0AEE96" length="1636824"/>
<jar name="core-java6-3.2.1.4.jar" crc="B87C35C4" length="543804"/>
<jar name="httpcore-4.4.13.jar" crc="2FCEAFE7" length="328593"/>
<jar name="httpclient-4.5.13.jar" crc="EC26836C" length="780321"/>
<jar name="miglayout-swing-4.2.jar" crc="DA98AC37" length="14580"/>
<jar name="common-io-3.4.1.jar" crc="E7D4BA58" length="90843"/>
<jar name="jheaps-0.11.jar" crc="67F79D2" length="133503"/>
<jar name="commons-io-2.2.jar" crc="11E1D2AE" length="173587"/>
<jar name="barcode4j-2.1.jar" crc="B907C79" length="274404"/>
<jar name="annotations-13.0.jar" crc="E6DD8E33" length="17536"/>
<jar name="xml-apis-1.3.04.jar" crc="9F219AB6" length="194354"/>
<jar name="jide-action-3.7.4.jar" crc="4EBE9458" length="228645"/>
<jar name="jydocking-3.4.0.jar" crc="AD8BB5BD" length="321925"/>
<jar name="logback-core-1.2.3.jar" crc="D9BC8F47" length="471901"/>
<jar name="xml-apis-ext-1.3.04.jar" crc="87389C28" length="85686"/>
<jar name="batik-transcoder-1.12.jar" crc="169E104E" length="128581"/>
<jar name="batik-constants-1.12.jar" crc="188FD9CD" length="8271"/>
<jar name="jide-plaf-9-0.0.1.jar" crc="83F57046" length="195573"/>
<jar name="jython-ia-2.7.2.1.jar" crc="A5AE7F4C" length="33892008"/>
<jar name="jide-diff-3.7.4.jar" crc="52C25AB0" length="154533"/>
<jar name="synthetica-3.4.0.jar" crc="27D0B8E3" length="711351"/>
<jar name="batik-parser-1.12.jar" crc="B8AD1229" length="76504"/>
<jar name="batik-svg-dom-1.12.jar" crc="2502C887" length="231948"/>
<jar name="batik-svggen-1.12.jar" crc="E2CD27B5" length="224908"/>
<jar name="jxbrowser-linux64-7.12.1.jar" crc="23C8C3EE" length="72334647"/>
<jar name="jide-grids-3.7.4.jar" crc="141BFEB0" length="2322572"/>
<jar name="batik-ext-1.12.jar" crc="D8C7ED74" length="10075"/>
<jar name="commons-cli-1.4.jar" crc="57B55D77" length="53820"/>
<jar name="jide-components-3.7.4.jar" crc="FD5B5C01" length="403617"/>
<jar name="batik-i18n-1.12.jar" crc="ECB4E1A" length="11263"/>
<jar name="xmlbeans-3.1.0.jar" crc="87DB6FAA" length="2579738"/>
<jar name="ignition-laf-3.1.0-beta8.jar" crc="D3A355F" length="405417"/>
<jar name="xalan-2.7.2.jar" crc="8C752A59" length="3154938"/>
<jar name="jytable-3.4.0.jar" crc="78172F73" length="187436"/>
<jar name="batik-anim-1.12.jar" crc="BEF50792" length="479193"/>
<jar name="jide-editor-3.7.4.jar" crc="5C2C00A9" length="471792"/>
<jar name="active-query-builder-8.1.18.jar" crc="AD0B5237" length="2642316"/>
<jar name="serializer-2.7.2.jar" crc="EC00A0FF" length="276420"/>
<jar name="launchclient.jar" crc="EEAE8D26" length="4693741"/>
<jar name="metrics-core-4.2.0.jar" crc="EDDA5463" length="125973"/>
</module>
<module name="webservicegateway" build="2022042818">
<jar name="__3893477523__WSClient.jar" crc="8CC6704" length="1572"/>
<jar name="__3893477523__WSDesigner.jar" crc="F2012BEF" length="308285"/>
<jar name="__3893477523__MESIgnition8Interface.jar" crc="4B0C3D79" length="63521"/>
<jar name="__3893477523__WSCommon.jar" crc="419048CF" length="163694"/>
<jar name="__3893477523__saaj-api-1.3.5.jar" crc="E4AE97C4" length="25423"/>
</module>
<module name="com.inductiveautomation.symbol-factory" build="2022061518">
<jar name="__1395368142__vision-symbol-factory-7.1.18.jar" crc="1BAE4B3A" length="35496398"/>
</module>
<module name="com.inductiveautomation.alarm-notification" build="2022061518">
<jar name="__2918011674__alarm-notification-common-6.1.18.jar" crc="4159E20C" length="25033"/>
<jar name="__2918011674__alarm-notification-designer-6.1.18.jar" crc="4107849B" length="208928"/>
<jar name="__2918011674__alarm-notification-client-6.1.18.jar" crc="AE816024" length="56922"/>
</module>
<module name="productiongateway" build="2022070723">
<jar name="__943155114__MESModuleManager.jar" crc="B9D015D6" length="3326"/>
<jar name="__943155114__ProductionCommon-test-fixtures.jar" crc="DF9F5CDE" length="6646"/>
<jar name="__943155114__byte-buddy-1.10.1.jar" crc="527B8DD7" length="3343525"/>
<jar name="__943155114__AnalysisEngine.jar" crc="B3DD7205" length="1061051"/>
<jar name="__943155114__jsoup-1.12.2.jar" crc="1A456103" length="391231"/>
<jar name="__943155114__super-csv-2.4.0.jar" crc="AA090C1A" length="98092"/>
<jar name="__943155114__ProductionCommon.jar" crc="E9DA142A" length="5549134"/>
<jar name="__943155114__ProductionDesigner.jar" crc="BBFA6462" length="3363780"/>
<jar name="__943155114__jxlayer-3.0.4.jar" crc="F89F71B6" length="48483"/>
<jar name="__943155114__MESIgnition8Interface.jar" crc="290A2D2" length="71849"/>
<jar name="__943155114__commons-collections4-4.4.jar" crc="6847F0D3" length="751914"/>
<jar name="__943155114__MonitorEngine.jar" crc="FAA1041E" length="61673"/>
</module>
<module name="businessconnectgateway" build="2022042819">
<jar name="__1067674058__jdom-1.1.3.jar" crc="2C577BAE" length="151304"/>
<jar name="__1067674058__MESModuleManager.jar" crc="7F2344F5" length="3308"/>
<jar name="__1067674058__MESIgnition8Interface.jar" crc="4B0C3D79" length="63521"/>
<jar name="__1067674058__BusinessConnectDesigner.jar" crc="CF406146" length="190738"/>
<jar name="__1067674058__jdatepicker-1.3.4.jar" crc="BD55C6E3" length="42949"/>
<jar name="__1067674058__BusinessConnectCommon.jar" crc="F6EBB139" length="452993"/>
<jar name="__1067674058__xercesImpl-2.12.0.jar" crc="53D2B0DC" length="1386397"/>
<jar name="__1067674058__jdom-contrib-1.1.3.jar" crc="8E8635B1" length="56424"/>
<jar name="__1067674058__xml-apis-1.4.01.jar" crc="BEEA12F4" length="220536"/>
<jar name="__1067674058__xmlbeans-3.1.0.jar" crc="87DB6FAA" length="2579738"/>
<jar name="__1067674058__SFCEngine.jar" crc="E1AC2A46" length="110405"/>
<jar name="__1067674058__jaxen-1.1.6.jar" crc="C13B2672" length="231882"/>
<jar name="__1067674058__jdom2-2.0.6.jar" crc="F3760977" length="304924"/>
</module>
<module name="com.inductiveautomation.sfc" build="2022061518">
<jar name="__347084201__sfc-common-5.1.18.jar" crc="15D8204C" length="133306"/>
<jar name="__347084201__sfc-designer-5.1.18.jar" crc="27F773CE" length="387100"/>
<jar name="__347084201__sfc-client-5.1.18.jar" crc="AEB65D26" length="143441"/>
</module>
<module name="com.inductiveautomation.opcua" build="2022061518">
<jar name="__246226664__opc-ua-common-9.1.18.jar" crc="DF17C439" length="2072"/>
<jar name="__246226664__opc-ua-client-9.1.18.jar" crc="C0CBB782" length="5603"/>
</module>
<module name="com.inductiveautomation.eam" build="2022061518">
<jar name="__1360034714__eam-client-4.1.18.jar" crc="76AB4F73" length="8605"/>
<jar name="__1360034714__eam-common-4.1.18.jar" crc="7B7EDD36" length="10557"/>
<jar name="__1360034714__eam-designer-4.1.18.jar" crc="E66E1324" length="43291"/>
</module>
<module name="tracegateway" build="2022070723">
<jar name="__1962485191__TraceDesigner.jar" crc="C85D6DF3" length="57758"/>
<jar name="__1962485191__TraceCommon.jar" crc="FFC4C1EB" length="711296"/>
<jar name="__1962485191__Prefuse.jar" crc="664C8629" length="775019"/>
</module>
<module name="com.inductiveautomation.sqlbridge" build="2022061518">
<jar name="__3456872652__sql-bridge-common-10.1.18.jar" crc="70910927" length="114160"/>
<jar name="__3456872652__sql-bridge-designer-10.1.18.jar" crc="BB4FA235" length="891147"/>
</module>
<module name="com.inductiveautomation.opcua.drivers.dnp3" build="2022061518">
<jar name="__3372776062__dnp3-common-4.1.18.jar" crc="E0F80728" length="2591"/>
<jar name="__3372776062__dnp3-designer-4.1.18.jar" crc="18865FC8" length="2353"/>
<jar name="__3372776062__dnp3-client-4.1.18.jar" crc="C6C9981C" length="4691"/>
</module>
<module name="com.inductiveautomation.serial-support-client" build="2022061518">
<jar name="__2822601402__jSerialComm-2.6.2.jar" crc="16F610F3" length="469932"/>
<jar name="__2822601402__serial-support-common-6.1.18.jar" crc="887152F8" length="15681"/>
<jar name="__2822601402__serial-support-client-6.1.18.jar" crc="2977C8D3" length="3091"/>
</module>
<module name="recipegateway" build="2022070723">
<jar name="__983045167__RecipeDesigner.jar" crc="D80D88C" length="562481"/>
<jar name="__983045167__RecipeCommon.jar" crc="79B725B4" length="2185137"/>
</module>
<module name="qualitygateway" build="2022070723">
<jar name="__1504315792__QualityDesigner.jar" crc="3D1F2948" length="2198451"/>
<jar name="__1504315792__QualityCommon.jar" crc="A6402C14" length="1557777"/>
</module>
<module name="com.inductiveautomation.vision" build="2022061518">
<jar name="__4070710095__vision-common-11.1.18.jar" crc="ECA4E1B6" length="13389"/>
<jar name="__4070710095__vision-client-11.1.18.jar" crc="EA480370" length="3182480"/>
<jar name="__4070710095__vision-designer-11.1.18.jar" crc="6603BA64" length="2925385"/>
</module>
<module name="oeedt2gateway" build="2022070723">
<jar name="__3597372810__OEE_DT2Common.jar" crc="1C7D9AB0" length="326291"/>
<jar name="__3597372810__OEE_DT2Designer.jar" crc="C8088EFF" length="195794"/>
</module>
<module name="documentmanagementgateway" build="2022070723">
<jar name="__1255209182__DocumentManagementDesigner.jar" crc="6BBF2EBF" length="124554"/>
<jar name="__1255209182__DocumentManagementCommon.jar" crc="A218B760" length="165585"/>
<jar name="__1255209182__HTMLEditorEnterprise.jar" crc="62629475" length="2112544"/>
<jar name="__1255209182__jsoup-1.12.1.jar" crc="B23E13E0" length="397112"/>
</module>
<module name="com.inductiveautomation.perspective" build="2022061518">
<jar name="__500613419__perspective-common-2.1.18.jar" crc="8982B614" length="363336"/>
<jar name="__500613419__perspective-designer-2.1.18.jar" crc="4A7A1F8C" length="2140947"/>
</module>
<module name="com.inductiveautomation.reporting" build="2022061518">
<jar name="__470274985__icepdf-viewer-6.3.2.jar" crc="9D046453" length="1232244"/>
<jar name="__470274985__bcprov-ext-jdk15on-1.69.jar" crc="4E8CAC61" length="5814235"/>
<jar name="__470274985__icepdf-core-6.3.2.jar" crc="C56894E2" length="1440836"/>
<jar name="__470274985__reporting-designer-6.1.18.jar" crc="C3CB1607" length="939811"/>
<jar name="__470274985__reporting-common-6.1.18.jar" crc="CD2CD39D" length="3525532"/>
<jar name="__470274985__poi-3.14.jar" crc="107E735E" length="2528204"/>
<jar name="__470274985__reporting-client-6.1.18.jar" crc="5EC3197A" length="2775491"/>
</module>
<thirdPartyModules md5="1d54d0519ff215174a8220b12c48c61e"/>
<connect usessl="false" port="8088"/>
</launch>
Claiming id in /home/USERNAME/.ignition/cache/gwIP_ADDRESS_8088...
... obtaining lock
... lock obtained.
... claimed id 1
Calculated necessary downloads:
<launch scope="D" framework="7" jreVersion="11.0.15" useCondensedDialogFont="false">
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
<thirdPartyModules md5="null"/>
</launch>
Local third party Python modules are different than the ones on the server. Will download updated modules now.
Downloading "http://IP_ADDRESS:8088/system/scriptModules"...
Connect successful.
Descrambling pylib bytes.
Starting download of 4464256 bytes
Third party Python modules downloaded.
Downloading "http://IP_ADDRESS:8088/system/translations/"...
Connect successful.
Starting download of 428 bytes
Download successful
Downloading the required Runtime for this gateways' clients.
Connect successful.
Descrambling runtime bytes.
Existing launchclient.jar can be used.
Releasing Client Cache Lock: 1
Running: [/home/USERNAME/.ignition/cache/resources/runtimes/11.0.15/bin/java, -cp, /local/home/USERNAME/.ignition/cache/launchclient_9FDDD1A6.jar, -Dsun.java2d.d3d=false, -Dsun.awt.fontconfig=/home/USERNAME/.ignition/cache/resources/runtimes/11.0.15/conf/fonts/fontconfig.condensed.properties, -Djavaws.sr.scope=D, -Dia.retarget.token=9FDDD1A6, -Djavaws.sr.memory.init=64M, -Djavaws.sr.memory.max=4096M, -Djavaws.sr.platform.edition=, -Dedition=, -Xms64M, -Xmx4096M, com.inductiveautomation.ignition.client.launch.BootstrapSwing, &]
Launched JVM.
The command in the log file was run as nohup but I did not run it with nohup so as to not obfuscate the output. As with previous executions, the pop-up window will appear, seem to complete and then come up again.
@jcoffman you have any idea what’s going on there?
It looks like something is getting in the way of identifying that the runtime is already downloaded. I haven’t seen this issue before. could you “manage” the designer you are launching and add the -Dignition.bootstrap.debugLog=true JVM argument? it should print out a new log file for each relaunch (basically each time it downloads the runtime) which might give us some insight as to what is happening. Do this:
clear the cache at ~/.ignition/cache
“manage” the application
Add the argument to the “JVM Arguments” section
Look in ~/.ignition/ for log files with the prefix launch_debug_ and grab the first and second log file (there are timestamps appended which should help identify them) and either post them here or DM them to me so i can look them over?
Thanks,
Jonathan C
Thanks Jonathan, DMd you the log file
To circle back here: It looks like there was an issue with the home directory here. /local/home/USERNAME and /home/USERNAME were being looked at for the .ignition folder. Im going to investigate this a bit more to potentially open a ticket internally to handle this on our end.
For now the workaround was to add a redirect.txt file in /home/USERNAME/.ignition pointing to /local/home/USERNAME/.ignition
Hi, I had the same issue with the Fedora based immutable distros silverblue/Kinoite and the uBlue derivatives Aurora/Bazzite.
In the above cases they where using:
- /local/home/USERNAME/.ignition
- /var/home/USERNAME/.ignition
Adding a redirect.txt file in /local/home/USERNAME/.ignition containing “/var/home/USERNAME/.ignition“ worked; designer now finally launches.
Just documenting this here as it (very) slightly different solution to the above.
