Unable to start Ignition
Hello all
I have recently installed 8.1 but have found that the Ignition service will not run.
Have checked the event viewer and it returns the following error:
‘The Ignition service terminated with the following service-specific error:
Incorrect function’
Have tried un-installing, and re-installing but it still has the same issue.
Kevin
You need to check the wrapper log and see what errors occured
Too bad the user didn't respond when they apparently fixed the issue. I'm having the exact same problem. However, the gateway does come up but won't restart after restoring my v7.9 backup. Any help would be greatly appreciated.
@blackdog
Thanks. I did that and found the error with help.
