We’re getting an Uncaught Throwable during execution error quite a bit. I’m sorry if this has been asked before but can’t figure out how to fix this. Error below.
This is on Ignition 7.9.7.
Thanks in advance,
Michael
INFO | jvm 1 | 2019/07/29 12:21:46 | W [c.i.i.c.u.SerialExecutionQueue] [20:21:46]: Uncaught Throwable during execution.
INFO | jvm 1 | 2019/07/29 12:21:46 | java.lang.StackOverflowError: null
INFO | jvm 1 | 2019/07/29 12:21:46 | at java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
INFO | jvm 1 | 2019/07/29 12:21:46 | at java.util.stream.MatchOps$MatchOp.evaluateSequential(Unknown Source)
INFO | jvm 1 | 2019/07/29 12:21:46 | at java.util.stream.AbstractPipeline.evaluate(Unknown Source)
INFO | jvm 1 | 2019/07/29 12:21:46 | at java.util.stream.ReferencePipeline.anyMatch(Unknown Source)
INFO | jvm 1 | 2019/07/29 12:21:46 | at com.inductiveautomation.xopc.drivers.logix.requests.ReadOptimizer.reservedType(ReadOptimizer.java:251)
INFO | jvm 1 | 2019/07/29 12:21:46 | at com.inductiveautomation.xopc.drivers.logix.requests.ReadOptimizer.lambda$null$6(ReadOptimizer.java:258)
INFO | jvm 1 | 2019/07/29 12:21:46 | at java.util.Optional.map(Unknown Source)
INFO | jvm 1 | 2019/07/29 12:21:46 | at com.inductiveautomation.xopc.drivers.logix.requests.ReadOptimizer.lambda$reservedType$7(ReadOptimizer.java:258)
INFO | jvm 1 | 2019/07/29 12:21:46 | at java.util.stream.MatchOps$1MatchSink.accept(Unknown Source)
INFO | jvm 1 | 2019/07/29 12:21:46 | at java.util.ArrayList$ArrayListSpliterator.tryAdvance(Unknown Source)
INFO | jvm 1 | 2019/07/29 12:21:46 | at java.util.stream.ReferencePipeline.forEachWithCancel(Unknown Source)
INFO | jvm 1 | 2019/07/29 12:21:46 | at java.util.stream.AbstractPipeline.copyIntoWithCancel(Unknown Source)
INFO | jvm 1 | 2019/07/29 12:21:46 | at java.util.stream.AbstractPipeline.copyInto(Unknown Source)
INFO | jvm 1 | 2019/07/29 12:21:46 | at com.inductiveautomation.xopc.drivers.logix.requests.ReadOptimizer.findReadableStructures(ReadOptimizer.java:189)
INFO | jvm 1 | 2019/07/29 12:21:46 | at com.inductiveautomation.xopc.drivers.logix.requests.ReadOptimizer.findReadableStructures(ReadOptimizer.java:200)
