Hi, I accidentally changed my gateway redundancy mode to backup, then back to master and somehow all the tags from my OPCUA went bad. Specifically to Uncertain using last known value. The connection in the gateway says it's good. And I can write into them from the vision hmi despite the objects being greyed out. What's happening? Is there a fix without restarting the gateway or my OPCUA server? Thanks.
The issue seems to happen when the node is in master mode, but not backup or independent. Why is that?
