I’m getting this error in the console, repeats every second.
com.google.common.util.concurrent.UncheckedExecutionException: com.google.common.collect.ComputationException: com.inductiveautomation.ignition.common.sqltags.parser.TagPathFormatException: Illegal character ',' (Line 1 , Char 35)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2203)
at com.google.common.cache.LocalCache.get(LocalCache.java:3937)
at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3941)
at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4824)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathParser.parse(TagPathParser.java:171)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathParser.parse(TagPathParser.java:157)
at com.inductiveautomation.ignition.gateway.sqltags.simple.SimpleTagProvider.getPath(SimpleTagProvider.java:82)
at com.inductiveautomation.ignition.gateway.sqltags.system.GatewaySystemTagsImpl.getPath(GatewaySystemTagsImpl.java:62)
at com.inductiveautomation.ignition.gateway.sqltags.simple.SimpleTagProvider.updateValue(SimpleTagProvider.java:100)
at com.inductiveautomation.ignition.gateway.sqltags.providers.AbstractStoreBasedTagProvider.scanclassStatisticsChanged(AbstractStoreBasedTagProvider.java:2118)
at com.inductiveautomation.ignition.gateway.sqltags.scanclasses.SimpleExecutableScanClass.notifyStatistics(SimpleExecutableScanClass.java:472)
at com.inductiveautomation.ignition.gateway.sqltags.scanclasses.SimpleExecutableScanClass.run(SimpleExecutableScanClass.java:905)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:584)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: com.google.common.collect.ComputationException: com.inductiveautomation.ignition.common.sqltags.parser.TagPathFormatException: Illegal character ',' (Line 1 , Char 35)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathParser$ParseFunction.load(TagPathParser.java:411)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathParser$ParseFunction.load(TagPathParser.java:404)
at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3527)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2319)
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2282)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2197)
... 19 more
Caused by: com.inductiveautomation.ignition.common.sqltags.parser.TagPathFormatException: Illegal character ',' (Line 1 , Char 35)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathLexer.errMsg(TagPathLexer.java:213)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathLexer.errMsg(TagPathLexer.java:217)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathLexer.yylex(TagPathLexer.java:735)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathParser._parse(TagPathParser.java:198)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathParser.access$200(TagPathParser.java:27)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathParser$ParseFunction.load(TagPathParser.java:409)
... 24 more
