Unicode from Variable
Hello Folks,
I’m trying to get some data from a web server, and get this data on perspective. But during the testes some data are in unicode formated with scape \u, I tried some ways to show the “right” text but no success, follow the example:
value = 'Folder Name: 8. Manuten\u00e7\u00e3o'
type(value)
print value
value2 = unicode(value,'utf-8')
type(value2)
print value2 #No Work
print u'Folder Name: 8. Manuten\u00e7\u00e3o' #Works OK
I I type directly on print the string with u’ works normal, but if try the same with a variable not work.
Anyone have a idea how to fix this issue?
Thanks in Advance!
A simple import from __future__ will fix your problem.
from __future__ import unicode_literals
type(value)
print value
type(value2)
print value2
Will produce the following output:
<type 'unicode'>
Folder Name: 8. Manutenção
<type 'unicode'>
Your first line should be:
value = u'Folder Name: 8. Manuten\u00e7\u00e3o'
Or use the __future__ import to always get unicode. The problem is that you must start with unicode. Once in a classic str(), you’ve already broken your chance to interpret the unicode correctly. You can’t do it after the fact.
So, if you are pulling from a web API, you must use methods that interpret UTF-8 as the data arrives. Please show the rest of your code, and explain the data flow more completely.
Thanks for the quick response guys.
I getting data from Microsoft Graph, to get DriveItens from specific Drive, They will return a Json with the information from the Sub Folder of a Document Library at SharePoint, and the information of Files in Root of drive
def getItensOnDriveItem(SiteID, DriveID, Path):
	import httplib, urllib, system, ast, shared.HTTP.SharePointV2
	token_expired = system.tag.readBlocking(['[default]SharePointApp/Token/token_expired])
	if token_expired:
		access_token = shared.HTTP.SharePointV2.GetToken()
	else:
		access_token = system.tag.readBlocking(['[default]SharePointApp/Token/access_token'])
	url = "/v1.0/sites/" + SiteID + "/drives/" + DriveID + "/root:/"+ Path + ":/children"
	conn = httplib.HTTPSConnection("graph.microsoft.com")
	payload = ''
	headers = {
	  'Authorization': 'Bearer ' + access_token
	conn.request("GET", url, payload, headers)
	res = conn.getresponse()
	data = res.read()
	return (ast.literal_eval(data.decode('utf-8')))
after cheking the reply from you guys, I found the issue, in the previous code I’m using the ast to convert JSON to Dict.
I replaced the code to use Json.Loads, and the Unicode are working fine now, if this code:
	import httplib, urllib, system, json, shared.HTTP.SharePointV2
	token_expired = system.tag.readBlocking(['[default]SharePointApp/Token/token_expired'])
	if token_expired:
	else:
	payload = ''
	headers = {
	data = res.read()
	return (json.loads(data.decode('utf-8')))
I am new and do not see how to post a new question, so I will continue from this related topic. I am using Ignition 8.1.24.
In the Expression Binding I can't enter unicode with a "u" prefix. Instead, I must hunt on the web for the rendered unicode, copy it, and paste into the Expression Binding text area.
#1 How do I enter raw unicode?
I found a degree symbol and it works in my project's Label. However, when I inherit that project into a parent project, the symbol has an "A" with a hat above it before the degree symbol. Why did that happen?
#2 How do I get inherited projects to display the exact same unicode?
