Hi, i have this timer that runs in a template (navigation).
When i left work on friday, i had no problems with this code line
event.source.parent.getComponent('lblTime').text = "<HTML>" + now.strftime("%A %Y-%m-%d %H:%M:%S") + "<BR>Användare: " + user.get(user.FirstName) + " " + user.get(user.LastName)
But today i get this error when the script has not changed since friday.
File "<event:actionPerformed>", line 9, in <module>
File "C:\Users\sg5551\.ignition\cache\gwlocalhost_8088_8043_main\C1\pylib\encodings\utf_8.py", line 16, in decode
return codecs.utf_8_decode(input, errors, True)
UnicodeDecodeError: 'utf-8' codec can't decode bytes in position 7-9: invalid data
at org.python.core.codecs.strict_errors(codecs.java:227)
at sun.reflect.GeneratedMethodAccessor76.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.JavaFunc.__call__(Py.java:2128)
at org.python.core.PyObject.__call__(PyObject.java:357)
at org.python.core.codecs.decoding_error(codecs.java:1264)
at org.python.core.codecs.insertReplacementAndGetResume(codecs.java:1240)
at org.python.core.codecs.PyUnicode_DecodeUTF8Stateful(codecs.java:756)
at org.python.modules._codecs.utf_8_decode(_codecs.java:72)
at sun.reflect.GeneratedMethodAccessor74.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:204)
at org.python.core.PyObject.__call__(PyObject.java:422)
at org.python.core.PyObject.__call__(PyObject.java:426)
at encodings.utf_8$py.decode$1(C:\Users\sg5551\.ignition\cache\gwlocalhost_8088_8043_main\C1\pylib\encodings\utf_8.py:16)
at encodings.utf_8$py.call_function(C:\Users\sg5551\.ignition\cache\gwlocalhost_8088_8043_main\C1\pylib\encodings\utf_8.py)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:301)
at org.python.core.PyBaseCode.call(PyBaseCode.java:127)
at org.python.core.PyFunction.__call__(PyFunction.java:317)
at org.python.core.PyFunction.__call__(PyFunction.java:312)
at org.python.core.codecs.decode(codecs.java:156)
at org.python.core.PyString.str_decode(PyString.java:2475)
at org.python.core.PyString.decode(PyString.java:2462)
at org.python.core.PyString.str___add__(PyString.java:722)
at org.python.core.PyString.__add__(PyString.java:716)
at org.python.core.PyObject._basic_add(PyObject.java:2009)
at org.python.core.PyObject._add(PyObject.java:1995)
at org.python.pycode._pyx15.f$0(<event:actionPerformed>:9)
at org.python.pycode._pyx15.call_function(<event:actionPerformed>)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:623)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:168)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:265)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at com.sun.proxy.$Proxy25.actionPerformed(Unknown Source)
at com.inductiveautomation.factorypmi.application.components.PMITimer.fireActionEvent(PMITimer.java:110)
at com.inductiveautomation.factorypmi.application.components.PMITimer.actionPerformed(PMITimer.java:124)
at javax.swing.Timer.fireActionPerformed(Unknown Source)
at javax.swing.Timer$DoPostEvent.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
Ignition v7.8.2 (b2016030813)
Java: Oracle Corporation 1.8.0_181
I figured out that the problem is around this part
This script has not been changed since 2016 and been working all the time except after this weeked.
