We are having a few problems with our equipment that is being run with Ignition. We can't seem to recreate the error but I found this error in the logs around when the problem was happening. Does anyone know what this error might mean?
Can you show the property change script that is throwing this error?
It's apparently on root.custom.RequestStopcodePopup
No, that doesn't look like it.
I would expect there to be a view with a custom property RequestStopcodePopup on the root with a property change script attached to it.
What you have provided is an onActionPerformed script, and the binding on some button.
You are showing the binding dialog when you should be showing us the event configuration dialog.
You've got a def with no executable code.
I think I had a problem with this once even though the action was disabled.
Try in this order:
- Put
passinto the funtion so it has something (nothing) to do. - Delete the action.
