Hello everybody,
I am facing an issue parsing a string date to date format using below code:
url"https://somewebsite.com"
token = 'some token'
headers = {'Accept': 'application/json','Authorization': token}
bypassCertValidation = True
source = system.net.httpGet(url,headerValues=headers,bypassCertValidation = True)
noaaJSON = system.util.jsonDecode(source)
#print noaaJSON
siteID = noaaJSON['result'][0]['siteId']
pollTime = str(noaaJSON['result'][0]['pollTime'])
print siteID
print pollTime
Date = system.date.parse(pollTime,"yyyy-MM-dd'T'HH:mm:ss.SSSZ")
print Date
Error code:
WWEF
2021-11-19T11:12:43.527Z ------ **This is the String date result trying to parse**
16:42:52.046 [AWT-EventQueue-0] ERROR com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter - <HTML>Error executing script for event: <code><b>actionPerformed</b></code><BR>on component: <code><b>Button 3</b></code>.
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last):
File "<event:actionPerformed>", line 12, in <module>
at java.base/java.text.DateFormat.parse(Unknown Source)
at com.inductiveautomation.ignition.common.script.builtin.DateUtilities.parse(DateUtilities.java:437)
at jdk.internal.reflect.GeneratedMethodAccessor382.invoke(Unknown Source)
java.text.ParseException: java.text.ParseException: Unparseable date: "2021-11-19T11:12:43.527Z"
at org.python.core.Py.JavaError(Py.java:495)
at org.python.core.Py.JavaError(Py.java:488)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:204)
at org.python.core.PyObject.__call__(PyObject.java:404)
at org.python.core.PyObject.__call__(PyObject.java:408)
at org.python.pycode._pyx334.f$0(<event:actionPerformed>:14)
at org.python.pycode._pyx334.call_function(<event:actionPerformed>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:636)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:193)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:284)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
at com.sun.proxy.$Proxy37.actionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.desktop/java.awt.EventQueue.access$500(Unknown Source)
at java.desktop/java.awt.EventQueue$3.run(Unknown Source)
Caused by: org.python.core.PyException: Traceback (most recent call last):
... 52 common frames omitted
Caused by: java.text.ParseException: Unparseable date: "2021-11-19T11:12:43.527Z"
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
... 49 common frames omitted
Thanks for Help
