I am using version 8.3.3 and Git for change traceability.
When I reject modifications (git checkout ) to a code.py file and its associated resource.json (this also applies to views, named queries, etc.), and then execute a “Scan File System,” the gateway does not pick up the changes.
If I restart a Designer, the rejected script is still shown as modified.The only way to force the changes to be taken into account is to restart the service.
Is there an additional step I might be missing in my workflow?
There are two different scan requests. One for project content, and one for global content. Which scan endpoint (or WebUI button) are you using?
I am using the “Scan File System” from the Gateway Web UI (Platform section), not from the Designer.
I wasn't talking about the designer. There are two different scan buttons in the WebUI.
For the average user who isn’t yet familiar with this workflow.
I didn’t realize that the “Scan File System” button behaves differently depending on whether it’s used from the "Overview" page or the "Projects" page.
Now that I understand this, it makes much more sense.
Unfortunately, I haven’t had time to go through all the documentation since the changes from version 7.9 to the current versions.
Version and Source Control Guide | Ignition User Manual
Thanks, @pturmel
