Hi Ignition community,
I'm currently in the process of updating my IO device library Exchange resource.
Starting by the Point IO 1734 serie.
This will have:
- Better quality picture for the faceplate (SVG)
- Fewer faceplate/popups The same type of card will be all together in one popup and will adapt the configuration in function of witch UDT is connected to the parameters.
- Integration wiring diagram in popup.
Any other suggestion is welcome.
One of my question is do i need to keep the popup layout/design has close to the original Rockwell library or should this be completely redesign to have a modern look en feel?
Here also any new design ideas are more then welcome.
Thanks for your feedback
Arnaud
