Update - Perspective module 1.02 to 1.04 - error
Hello,
i tried to upgrade ignition, and upgrade of module Perspective faulted.
I tried to uninstal module and add again, and it still fails, i also tried to downgrade to 1.02 but this one also failed.
What should i do?
Thank you
Version: 8.0.4 (b2019091612)
It shows error:
java.lang.IllegalArgumentException: Servlet map already contains "pws"
	at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.addServlet(MapServlet.java:107)
	at com.inductiveautomation.ignition.gateway.web.WebResourceManagerImpl.addServlet(WebResourceManagerImpl.java:233)
	at com.inductiveautomation.perspective.gateway.GatewayHook.setup(GatewayHook.java:141)
	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.setup(ModuleManagerImpl.java:2325)
	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.startupModule(ModuleManagerImpl.java:1169)
	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$2.call(ModuleManagerImpl.java:734)
	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.executeModuleOperation(ModuleManagerImpl.java:920)
	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.installModuleInternal(ModuleManagerImpl.java:696)
	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$InstallCommand.execute(ModuleManagerImpl.java:1855)
	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$Receiver.receiveCall(ModuleManagerImpl.java:1805)
	at com.inductiveautomation.ignition.gateway.redundancy.QueueableMessageReceiver.receiveCall(QueueableMessageReceiver.java:47)
	at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.dispatchMessage(RedundancyManagerImpl.java:852)
	at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl$ExecuteTask.run(RedundancyManagerImpl.java:924)
	at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
Azul Systems, Inc. 11.0.4
I’ve seen a similar problem in module development–had to restart the gateway service itself.
Thank you, gateway restart solved my problem.
