So I started with my SQL Code within the Database Query Browser and I was able to do an update query with no issue
This is just a basic edit row SQL script so I could make sure I got the syntax correct:
UPDATE sensor_notes
SET operator = 'admin'
WHERE operator = 'rodney'
Then I took this code, and tried to make it dynamic so that the user would be able to edit data within the database based on text fields within the screen. This is what I got:
[code]name = event.source.parent.getComponent(âText Field 4â).text
operator = event.source.parent.getComponent(âText Field 5â).text
latitude = event.source.parent.getComponent(âText Field 2â).text
longitude = event.source.parent.getComponent(âText Field 3â).text
description = event.source.parent.getComponent(âText Field 1â).text
db = âDBâ
updateQuery = âââUPDATE sensor_data SET name = ?, operator = ?, latitude = ?, longitude = ?, description = ? WHERE name = ?
VALUES (?,?,?,?,?,?)â""
system.db.runPrepUpdate(updateQuery, [name, operator, latitude, longitude, description, name], db)[/code]
Unfortunately, I keep getting an error code
This is the entirety of the error I keep getting:
File âevent:actionPerformedâ, line 10, in
VALUES (?,?,?,?,?,?), [Sensor 2, Dave, 12.34, 2.4.68, D2, Sensor 2], DB, , false, false)
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(UPDATE sensor_data SET name = ?, operator = ?, latitude = ?, longitude = ?, description = ? WHERE name = ?
caused by Exception: Error executing system.db.runPrepUpdate(UPDATE sensor_data SET name = ?, operator = ?, latitude = ?, longitude = ?, description = ? WHERE name = ?
caused by GatewayException: SQL error for âUPDATE sensor_data SET name = ?, operator = ?, latitude = ?, longitude = ?, description = ? WHERE name = ?
VALUES (?,?,?,?,?,?)â: No value specified for parameter 7
caused by SQLException: No value specified for parameter 7
Ignition v7.7.5 (b2015071516)
Java: Oracle Corporation 1.8.0_51
Any ideas as to whatâs going on? It says no value specified for parameter 7, but I only have 6 parameters there, right? Iâm just a tad confused as to whatâs going on ![]()
Iâm currently running Version 7.7.5, so I believe that I am up to date on my software as well.
Thanks in Advance for all the help!
